Sony Ericsson XPERIA S LT26I Nozomi Arc HD Logo
Anonymous Posted on May 23, 2013
Yellow tint My Xperia S LT26i suddenly become a yellow screen and i can not see the images or the pictures on its colors. It all become yellow. How to change it to become normal again? I don't change any thing on the setting. It suddenly become yellow screen.. PLS help
aamir khan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 29, 2015
aamir khan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
119
Points
What is your mother's maiden name?
mohd shaiful
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 19, 2013
mohd shaiful
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2530
Points
How to remove password sony xperia LT26i
How do u unlock password on a sony xperia lt26i
Do you want unlock sony xperia lt26i mobile network lock password? You can visit this site Unlocking4u.com here you can get the unlock code and unlock your cell phone. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
http://www.unlocking4u.com/sony-ericsson-lt26i/rs6wp9/
May 30, 2014 • Cell Phones
2helpful
3answers
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
1helpful
3answers
Security code forgotten...sony xperia lt26i how to crack it or erase security question?
i have forgot the email and passwords, i forgot the pattern lock and also i do not remember the security question. How do i Ultimately unlock the phone and turn the lock off?? do i have to do a format or hard reset to clear off the passwords? - how do i do that??
1helpful
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
My tv sceen has a stain that makes anything white look yellow.
The color image is comprised of three colors, Red, Green, and Blue.
All the other colors are mixtures of those colors. The yellow picture indicates that your set is lacking sufficient blue drive.
First of all check to make sure that the tint control is not misadjusted.
The next thing is dependent upon the age of your television. If it's an older set that yellow tint is a sign of an aging picture tube.
If it's a newer set, less than 5 years old, have it analyzed by a electronics technician that is familiar with televisions if he is skilled enough he will know right away if it's the picture tube or not.
1helpful
Yellow tint no color red.
you can adjust in color mode. please balance the tint, color,brightness, contrast, & sharpness.
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Top Sony Ericsson Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
