The pull cord has no tension to make the engine start
When pulling the cord to start the engine there's a lot of play in the cord like something is detached. is this something i might be able to repair myself?
no tension in the cord to make it start. local repair center does not do to this type of work. should I go back to sears or do I order the part and fix it myself?no tension in the cord to make it start. local repair center does not do to this type of work. should I go back to sears or do I order the part and fix it myself?
You can't post conmments that contain an email address.
Re: the pull cord has no tension to make the engine start
It seems you do not have enough spring tension. Remove the starter housing and grab the slack rope and wind the pulley two or three times in the tension direction until the slack gets pulled into the pulley by the spring. Hope this helps. Donnyb60
Hi Jack:
You don't mention make or model so all I can do is relate 50 years of personal experience.
None of the chain saws that I have owned have had a fuel primer.
This has been (and continues to be for my Husky 266) my start routine. Current saws don't have compression release.
- prep includes fill fuel and oil tanks, check chain sharp and tension, bar tip lube.
- Ignition switch on
- Choke full on
- Throttle full and lock set.
- Pull starter cord *(266 takes 3 pulls, Homelite took 6) until engine fires. If I'm fast I can get the choke off before it dies, otherwise
- Choke off, Pull starter cord. Engine should start with 1 or 2 pulls.
Hope this helps.
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
If the rope recoils back into the starter, at least the starter spring is not broken...but...if you can break the unit down to where you can get a good look at it, you may find that the ratchets on the starter pulley are not engaging with the pawls on the flywheel...The pawls are spring loaded so they engage and then drop out of the way when starting, See if you can break the machine down to that point and post back,
When the cord breaks, the internal spring will completely unwind. You have to re-tension the spring, then attach the cord and wind it onto the spool while holding the spool against tension. Finally, feed the end of the cord out through the cord port and tie the handle while still holding tension. A small pair of Vise Grip pliers will hold the cord while dealing with the handle. It's about like setting a trap without getting your fingers caught. Hope this helps!
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
