My phone, sony ericsson k800i is jammed although i started the phone, the screen only appeared the main menu. i press any button but it don't work but if i started the phone without sim card, i press the button and it work but, well you know, it only show 'demo'. i hope someone can help me
SOURCE: sony ericsson k800i blank screen need to transfer numbers from phone memory to sim card
Thats a cool phone, pity its screen is broken.... Here is my suggestion
Check the memory card or Sim on another phone...
SOURCE: Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
SOURCE: Sony Ericsson - phone lock code
Hi Cheryl!!!
I think i may have a solution for u. It sounds like a Phonelock code...all Cellphones have one. Its in the software for the phones. Its a little like a SIM code. U could try with entering the code 0000. That could work!!
Good Luck :-)
SOURCE: i cant reset my sony ericsson k800i phone no screen need screen to reset HELP
First of all backup if possible your every important thing because further steps erase your all phone data.Switch off ur phone hold
*,3 and green call button at the same time and switch on your
phone.problem resolved.
Regards,
Sandeep Singh
SOURCE: my sony ericsson k800i phone has a problem with signals
hello
the problem is with your phone's hardware
