No prior probs. One day it shows: Win Vista Hm Premium product key is invalid for activation. 3 options are: contact Gateway, retype access code or use limited functionality. None work!
There is a Support Doc: "You may be prompted to activate Windows Vista on a computer on which Windows Vista was already activated by a Volume License or OEM installation" at http://support.microsoft.com/default.aspx?scid=kb;EN-US;931573 That I beleive is specific to your issue. Please follow the resolution portion of the doc.
The that does not resolve your issue, please follow the steps below. If the first set of steps does not resolve, move on to the next set of steps.
Step set #1
(If you access to the start button)
1) Click the Start button
2) Type cmd in the Start Search field
3) At the top the Start window, you will see cmd.exe
4) Right Click cmd.exe and select Run as Administrator
5) Type: cscript %windir%\System32\slmgr.vbs /ilc %windir%\System32\licensing\ppdlic\Security-Licensing-SLC-ppdlic.xrm-ms
6) Hit the Enter key
7) Reboot 2 times
(If you Do Not access to the start button)
1) Click the option Access computer with reduced functionality
2) A Browser will open, type: %windir%\system32 into the address field
3) Find the file cmd.exe
4) Right Click on the cmd.exe and select Run as Administrator
7) Reboot 2 times
Step set #2
2) Type: slui.exe 3 and hit the Enter key
3) Type in the Product key from the sticker on your computer
4) Click the Next button.
5) You will be asked if want to Activate, click ok
6) It will attempt to Activate by the internet and will return an Invalid Key error (this is ok, continue to step 7)
7) Click the Start button
8) Type: slui.exe 4 and hit the Enter key
9) Select your location in the drop down menu and click the Next button
10) The next screen provides the number to call to Activate by Phone
NOTE: when you call that number, you will first hear an Automated Voice that will try to Activate Vista for you. If the Automated Voice gives you an option to talk to a Live Activation Rep, select that option. If not, do not enter any numbers. This should force the Automated Voice to transfer you to a Live Activation Rep. Trying to Activate thru the Automated Voice will not work, in your case, only thru the Live Activation Rep will your Activation be successful.
Once completed, you may need to reboot twice.
1) Click the option 'Run with reduced functionality'
2) A internet Browser should come up, type: %windir%\system32\cmd.exe in the browser address bar
3) A window with a black background will come up
4) Type: slui.exe 3 and hit the Enter key
5) Type in the Product key from the sticker on your computer
6) Click the Next button.
7) You will be asked if want to Activate, click ok
8) It will attempt to Activate by the internet and will return an Invalid Key error (this is ok, continue to step 9)
9) Return to the window with the black background
10) Type: slui.exe 4 and hit the Enter key
11) Select your location in the drop down menu and click the Next button
12) The next screen provides the number to call to Activate by Phone
NOTE: when you call that number, you will first hear an Automated Voice that will try to Activate Vista for you. If the Atomated Voice gives you an option to talk to a Live Activation Rep, select that option. If not, do not enter any numbers. This should force the Automated Voice to transfer you to a Live Activation Rep. Trying to Activate thru the Automated Voice will not work, in your case, only thru the Live Activation Rep will your Activation be successful.
Step set #3
1) Open Internet Browser
2) Type %windir%\system32 into the browser address bar.
3) Find the file CMD.exe
4) Right-Click on CMD.exe and select Run as Administrator
5) Type: net stop slsvc (it may ask you if you are sure, select yes)
6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
7) Type: rename tokens.dat tokens.bar
8) Type: cd %windir%\system32
9) Type net start slsvc
10) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
11) Reboot Twice
12) You may be required to Re-Activate. Use the Activate by Phone method outlined below
Activate by Phone steps:
a) If you have access to the Start button: Click the Start button, and type in "slui.exe 4" in the search field and then press the "Enter" key. This will bring up the Activate by Phone dialog window. Follow the steps provided by the window. The phone activation process should only take about 6 minutes.
b) If you do not have access to the Start button: Reboot and login to Vista, a dialog window will come up. In that window, click the option "Access computer with reduced functionality". Once you do that, Internet Explorer or Firefox browser will open. In the address bar type "c:\windows\system32\cmd.exe" press enter, a new window will come up, type: slui 4 and hit enterand follow steps to Activate over the Phone.
NOTE: The key to this process is that you need to talk to a Live Activation Rep! When you first call, you will be interacting with an Automated Voice, either select the option to talk to a Live Rep or if there is no option, do not enter any numbers. This should force the automated voice to tansfer you to a Live Rep.
Call Microsoft.
Microsoft Windows Vista Consumer Product Activation Phone Number:
1-866-740-1256
Good luck with this.
Hi, My Name is Henry. I am one of the technicians here.
The only solution to this problem is to install a new windows. the moment it gave you that error message that was when the windows seized to work.
You can go ahead and contact Microsoft about the problem if you think the software is genuine and its from them.
Besides that, Get a new hard drive if you can, install a new windows on it and then attach the old hard drive as a secondary or slave so as to get all your data back.
If the data didn't mean anything to you, just reload and install an brand new windows operating system.
Regards
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
