I have replaced all batteries, recharged and purchased new batteries etc. It will not switch on. I have checked all polarities to make sure ther were inserted the right way. The camera is less than 1 year old. Any ideas? Trouble shooting doesn't give any more details for this apart from the battery replacement/polarity.
My vivitar Vivicam 9126 come on but ends at test result. Pressing any button does not work. I can only remove the batteries before it can go off. Pls, what should I do to resolve this?
SOURCE: Optional DC Battery Pack Use
Thanks for contact us. Mr.JazzyMike As u described, i think there is serious problem in your camera.I suggest as follows * If you are familiar to open the camera,safely open it. * safely discharge C612 located on power/flash board. * Then safely pull out power/flash board from the chasis. * Then check fuses no. F 500,F 501,F 503,F 504,F 505, F 506 if any of them found blown replace it and then go back. SAFETY : TAKE SPECIAL CARE OF CONNECTORS AND FLEX PWB. Dont use external battery pack for any digital camera. If you are not succeed contact us. mail us : [email protected]
SOURCE: battery not recharging
Hi
You can't charge your battery while it is in the camera; the USB cable that connects to your computer is for transferring pictures not charging the battery.
Thomas
SOURCE: camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
SOURCE: C913 camera will not turn on - after new batteries
Try to clean the battery terminals of the camera, if there is any kind of rust, remove it.
Keep the camera off for a day with battery and memory card taken out.
Now insert the battery and memory card in and switch it on.
If still theproblem persists then there is problem with the internal circuit as the charge from the battery is not flowing in it. Then you will have to take your camera to a Kodak Repair center to get it checked.
Good luck and have a nice day.
