2 amp fuse blows often. Told it might be a short in circuit board. What is the way to fix this?
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
