We moved the spa, rewired and started,pump ran, heat light on, in the morning nothing, sounds like GFI breaker is tripping and K3 clicks, removed left hand heater copper connected GFI stays energized. RH heater stud corroded. Removed heater tube, how can I test to make sure it is the heating element? 5.5KW 15" 2x2" M7 w/stud
SOURCE: Colman Spa trips GFI what is most common problem?
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
