Does anyone know how to program a Toyota Altezza (Lexus IS300) 2 button remote key?
SOURCE: programming remote to open doors
Dear Customer,
If you didn't change your remote kit than its a best way to take to your dealer ,there is minor problem with sequence so they wil do free of cost with car document.
THNX
SOURCE: Lexus trunk locked - No key
you can take out the back seat ..that way you can get at the release lever........
SOURCE: i locked my keys in the trunk of my 2000 toyota corolla ce,
Hi I'm litoshop and yes you can get in the trunk through the back seat it not that hard good luck. if this information has been useful please let us know thank you
SOURCE: Having a challenge programming a 1999 Lexus RX 300 newly cut key.
did the lock smith cut key with resister in in maybee not gotta go to dealer get one cut then put old key in start car then turn of remove key put new key in turn on till security light goes out then start car
SOURCE: my key wont unlock the trunk anymore but the remote opener does.
There is a cable that runs from the key cylinder to the latch mechanism. There are clips that hold the cable housing in place, and if one of those comes loose then turning the key just moves the housing without releasing the latch. Check the clip closest to the latch. To get the trunk open drop the back seat, crawl in, and pull on the cable.
It is also possible that the cable is broken or damaged and needs to be replaced -- I assume you will then need to replace the enrite assembly.
Try this:
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
