How do you download AMV movies onto the JNC player ?
Are there any sites available....
Just don't know where to turn !!! Have searched Google flat.
How to convert wmv, asf, avi, mpg to amv files?
iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
Buy Now Download RMVB Video Converter free trial How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use progAMV movie dowloads - JNC Movie Mojo ( SSFM-220 ) - amv-converter.jpge way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
AfteAMV movie dowloads - JNC Movie Mojo ( SSFM-220 ) - setting.jpgo files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
