It probably has a bad main control board , locate behind the refrig , behind an 8x10" panel . I would remove the board ( with refrig unplugged ) , and look for a " bullseye " . Resolder if possible , if not , replace the control board . From your symptom , sounds like the compressor is not comming on , so the board should fix this .
If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
