JoWood Productions Neighbours From Hell 2 for Windows Logo
Anonymous Posted on May 21, 2013
Core i3 i dont know download this game
Harlem Shake
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on May 21, 2013
Harlem Shake
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
2704
Points
13
Can not used for hard game
Aspire V series is not for hard core games..If you want laptop that good for hard core games, look for laptop with dedicated graphics memory (atlease 1GB dedicated memory). Although it has a good processor (i3) i think it's not enough.
My Dell INSPIRON goes very hot and shut down after a while
FIRST CHECK LAPTOP RUNNING OR NOT
DONT USE LAPTOP ON BED
DONT USE TABLE CLOTH UNDER LAP
CLEAN THE HEAT EXTRACT AREA WITH AIR PUMP
CHECK ALL DRIVERS INSTALLED OR NOT
2helpful
Enable hypthreading i3 2120
The Intel Core i3, model 2120 Microprocessor is based on the Nehalem micro-architecture,
http://en.wikipedia.org/wiki/Nehalem_%28microarchitecture%29
In the old days you had Intel Pentium 4's, that had Hyperthreading Technology. HT.
One REAL processor core operating, and one VIRTUAL processor core.
The Processor teamed up on the task at hand, using TWO processor cores.
Yes, you guessed it. TWO processors.
One REAL, one VIRTUAL.
The Nehalem micro-architecture brought HT back out.
Then the Sandy Bridge micro-architecture came out. Came out to replace the Nehalem micro-architecture,
http://en.wikipedia.org/wiki/Sandy_Bridge
The Intel Core i3 2120 is based on the 32nm Sandy Bridge, micro-architecture.
http://en.wikipedia.org/wiki/Sandy_Bridge#Desktop_platform
Now instead of having TWO processor cores, you can have FOUR with two REAL ones, and two VIRTUAL ones.
FOUR processors is what is essentially being said here.
TWO real ones, TWO virtual ones.
HOWEVER, your load that you are doing;...............
Internet searches...
Business/Office application, or program...
Game...
Video editing...........
Is not enough to use FOUR processor cores. So HT is not enabled at this time.
An aggressive, intensive new game, will click HT on; but who am I to know?
Program that you have multiple applications within it opened?
Running four or more programs?
Running two games at once?
Editing the lunar space program? lol!
Maybe THESE will kick HT on, dunno.
For additional questions please post in a Comment.
Regards,
joecoolvette
[Having HT with a processor that has TWO processor cores; is like having an alcohol burning dragster processor.
You don't use it to go to the supermarket ]
[Oh, and by the way;
NO, Intel Core i3 does NOT mean 3 processor cores.
There are TWO.
Processor Core:
Having two processor cores on ONE die chip; means there are TWO processors.
TWO processors contained in that one processor.
HT is kicked on you have FOUR processors ]
http://www.hardwaresecrets.com/article/535
http://www.hardwaresecrets.com/article/Inside-the-Intel-Sandy-Bridge-Microarchitecture/1161
http://www.hardwaresecrets.com/article/All-Core-i3-Models/951
[Yours is a 21xx Model ]
Can a Intel Core I3 be installed in a Emachines D725
No. Not the one listed above (socket LGA 1156) You need to look for a mobile CPU (possibly mobile 479). They differ physically and architecturally. Even then you need to establish that the CPU is removable and verify BIOS has support for upgraded chip. Talk to your local repair shop for finale decision.
6helpful
3answers
Which is the perfect OS x86 or x64 for intel core i3 cpu 530 @ 293 ghz
The i3 cpu is a 64 bit processor, therefore it will suit 64 bit Windows OS.
I dont have web-camera' i dont know if i delete before. because i want to use in my acer aspire5741 intel core i3-330m laptop.
Sure you have web camera in that laptop but probably you unistaled or deleted some application to install go to this link download what you missing
http://support.acer.com/us/en/product/default.aspx?modelId=2057
2helpful
Actually i just wanna ask about the core i3 HD graphics on intel DH55TC motherboard does this processor support shader 3.0 on games ??
Hi.
Yes, you have an i3 processor, which allows for blazing fast gaming graphics with the graphics media accelerator.
It supports directx 11, and has pixel shader 3.0 support as well.
It allows the processor to offload the graphics signal to the graphics portion of the motherboard, allowing the processor to work way more efficiently
It has support for vertex shaders as well as the normal pixel shaders, so graphics come alive.
Just check which type of graphic chipset that you have, and download the latest drivers for it.
Some have intel chips, some have ati, and others have nvidia.
They all work equally well for the most part, for games it seems that the nvidia chips appear to work a little smoother than the ati, but the ati has it's pluses as well. The ati chips can run at a faster overall speed.
Make sure that you set the AGP aperture to the maximum amount available in your bios settings
How can i use oracle in win 7 platform of i3 processor?and which processor is best core 2 duo or core i3?
Windows 7 Release Candidate was publically released on May 5, 2009. This should be the final release before it goes live later this year. download it, install it in a VM inside of VirtualBox and try to install Oracle on it. There is no Oracle release for Windows 7, so instead grab the Windows 2008 one. The install is pretty straight forward. The only "gotcha" is that if you go to the command prompt, you need to run it as the Administrator, so that all of the Oracle commands will work (lsnrctl, dbca, netca etc...) Really there is not that much to it as it was pretty seemless. So, if you download Windows 7, then you can also download Oracle 11g and start playing with it today!
Here is the second answer
We live in the times where computing power, once available only at the level of super computers, has been made available to the common man. The forerunner in the race, who's probably miles ahead of its competitors is the computing giant Intel. According to the needs of computer users, Intel delivers chips with varying degrees of power and clocking speed. These include the entry level, mid level and high end processors. The latest entry level Intel chips to hit the market are the core i3 processors which are aimed at taking up the place previously held by the core 2 duo processors. The new hierarchy of Intel chips in ascending order of computing power are the core i3, core i5 and core i7 processors. Although core 2 duo processors are slowly being phased out of production, they are still available in the market. In this article, I present a core i3 vs core 2 duo review which may help you decide which one to go for.
Intel Core i3 Vs Core 2 Duo Comparison
A comparison between processors was simple some years ago with a single core processor. All you had to look at was the clocking frequency and the cache size. The entry of multiple core chips changed it all and life became complicated. With dual, quad and even six core processors hitting the market, there are many more factors to be considered than before. Intel's dual core and core 2 duo processors were the first ones to introduce the multicore processor computing power. The quad processors created later have given rise to the quad core vs dual core debate, as well as the core i5 vs core i7 comparison which is something that high end computing market consumers should think about. Prior to that, we only had the 32 bit vs 64 bit processors comparison.
Today, Intel has gone through a lot of designing and planning to introduce core i3 processors that are an improvement over the core 2 duo processors. The following Intel core i3 vs core 2 duo processor comparison will give you an idea about how the i3 processors are different from their dual core predecessors. The two points of comparison will be technical specifications and the only other factor which matters that is performance.
Core i3 Vs Core 2 Duo: Technical Specifications
Like the core 2 duo processors, the new core i3 line of processors, have two cores with many other technological enhancements including an integrated GPU (Graphic Processing Unit). The clocking frequency of the core i3 series of processors ranges from 2.26 GHz to 3.06 GHz. Each processor is endowed with the new line of advanced technologies including Intel developed hyperthreading, Intel virtualization and smart cache technology which makes these chips faster than core 2 duo processors. This is the most important point in the core i3 vs core 2 duo comparison.
The Intel codename for core i3 architecture is Clarkdale. They are based on the Westmere architecture with 32 nm fabrication and a direct media interface (DMI) bus. The socket type used for core i3 processors is LGA 1156 and the RAM type is DDR3. They support mother boards with the following types of chipsets- H55, P55, H57 and Q57.
Let us have a look at the latter processors in the core i3 vs core 2 duo comparison. Core 2 Duo processors come in three types of architectures, codenamed as Conroe, Wolfdale and Allendale. With 65 nm and 45 nm fabrications they are a tad slower and less power efficient than the 32 nm based core i3 processors. The socket used for core 2 duo processors is LGA 775 and they come with a FSB bus. The FSB bus is a lot slower in operation than the DMI bus in core i3 processors.
Coupled with the fact that the i3 processors have a L2 cache size of 2 x 256 kb and a L3 cache size of 4MB, with hyperthreading and smart cache enabled, core 2 duo processors are indeed slower. On top of that, DDR3 RAM compatibility in core i3 processors, compared to DDR2 compatibility of core 2 duo processors makes them even more faster. The price range of Intel core i3 is $100 to $133, which makes them top options in the entry level market.
Core i3 Vs Core 2 Duo: Performance
The technical specifications have made it clearly indicated that Intel core i3 beats its predecessor, core 2 duo in almost all departments. This is but natural as they were indeed designed to replace them. Be it processing speed, multitasking or graphic output, opting for core i3 processors is the logical choice to make!
Hope the core i3 vs core 2 duo processor comparison provided in this article has made it easier for you to choose the right processor for your personal desktop computer or laptop computer. Going for a more advanced line of processors is always beneficial in the long run. You should also check out the Intel core i5 and core i7 processors before going ahead as they offer far more computing power and speed, compared to the entry level core i3 or core 2 duo. Decide on the processor you want according to your usage requirements and of course giving due thought to your vitamin 'M' levels!
Top JoWood Productions Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
