Your VS-2000 is showing symptoms of fragmentation--resulting in the unit
freezing or failing to completely load. The only possible solution is
formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our
Roland Customer Support department (323-890-3740) to arrange a "Data
Recovery" service. Our service technicians can attempt to recover any
data that is in your hard drive. Customer Support is available M-F
8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard
drive erases ALL recordings and data on the drive. This includes any
installed plug-ins as well. Be sure to back up all of your project data
(recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System: 1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue
holding the two buttons until the display has loaded completely. This
can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board
LCD screen. If you're using an external VGA (video monitor), press and
hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
Those are common error on the XBox 360, after some extended use. You can try to send it to be repaired, and if it happens again, consider the purchase of a newer model.
You may have a motherboard failure problem. I would ask you to check the drivers and update them but will be hard to do if you can't get past load screen. You best bet may to get a copy of system recovery and boot pc with the disk installed. Wipe computer completely clean and reinstall windows.
I'm having the same problem! I contacted support and the guy swears its the CDs im using, he says they're **** (memorex, sony, etc etc). he recommended "Micro Boards" brand.
He also said that if that doesn't fix the problem, it might be a fragmented disk which will need to be re-formatted or replaced.
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
I have 3 2480s and I use them professionally so I think I can help you. Looks as if you need to install the OS for the system. It seems as if it lost. You should have the OS on CD and if not contact RolandUS and get one. You would put in the OS into your CD burner and power up the unit. I would recommend Roland HD support be on the other end if you are brand new. They will walk you through. I was one of the first to buy the 2480 when it came out and the manual is just insane to learn.
I have figured out a way to get around this problem without losing your data or sending it to Roland.
I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
