When I turn on the T.V. the Sounds works for about thirty seconds then stops but the picture remains the same. Also My DVD Player never has sound, I have tried both HDMI Hookup and AV Cables. I Have Direct TV Satellite Box number is TV D12-100. The DVD Player is a Sony DVP-SR510h. I have tried a number of things with the sound setting on all three of these devices. I have not done a hard reset on the T.V. But I am going to do that next. Any Advice would be much appreciated. I run a B&B and have a guest that is staying in the room where the T.V. is tonight. So I need an answer ASAP. Thanks
SOURCE: I have an ilo 32hd
Unfortunately the ILO TVs aren't a good investment. If you just purchased the television, I would return it as soon as possible and purchase a more reliable and well known brand. ILO support services is almost non-existant and there are several comments on other blogs regarding the Ilo brand. I have two ILO 26" HD, which I purchased in Aug '06 and am now beginning to experience problems.
SOURCE: Sony Bravia with Phillps dvd player
It's not compatible with the Phillips DVD player. We had the same problem with our old DVD player, something about reading it.
SOURCE: connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
SOURCE: Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Any input at all is appreciated. Thanks!
