Instead of suctioning in, there is air blowing OUT through the front Hepa air filter on the front of vacuum. Also the beater brush/bar on the bottom rotates while lifted in the air, but stops rotating when lowered to the floor or carpet. Nothing blocking hoses. Can anyone help?
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
