Question about Ardisam Inc Earthquake Mini Cultivator
Tines I have Earthquake Mini Cultivator; engine runs fine but tines won't turn?
  • 112 Answers
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
Posted on Jun 04, 2013
SOURCE:
boscia
  • 163 Answers
SOURCE: older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Posted on Nov 30, 2008
  • 112 Answers
SOURCE: rewind on earthquake mini cultivator won't rewind
Call 1-866-598-2128 for parts, they are in Appleton, Wisconsin.
Posted on Jul 15, 2009
  • 10 Answers
SOURCE: I need a primer bulb
search amazon.com w/ your model #should be numerous retailers w/it also you could carry it to your local power equipment dealer and they can match it up there are only a few carb manufacturers.
Posted on Apr 12, 2010
  • 198 Answers
SOURCE: our earthquake 43cc cultivator won't start. it has
the carb might need a thorough cleaning---remove and disassemble---clean all parts in solvent.
Posted on May 10, 2010
  • 6 Answers
SOURCE: have been on the computer all morning many diff
Select the model on this website and then the part. The link below is for MC43E Mini Cultivator http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43E
Posted on Jul 19, 2010
Why is the belt wearing out so quick, i have used my brand new earthquake rear tine tiller less than ten hours and have gone thru three belts.
-The pulley, idler are not line up and may be too sharp edges. or may be some other part is touching the belt when is running.
Good luck
mai
Jun 08, 2014 | Ardisam Inc Earthquake Mini Cultivator
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Motor runs, tines turn. won't dig deep. Can't find belt.
This is a direct gear drive system, (It doesn't have a belt) It also only has a 4 inch digging depth by specs so anything deeper than that is great.
Nov 29, 2010 | Ardisam Inc Earthquake Mini Cultivator
Have been on the computer all morning many diff sites getting a nervous breakdown want tine geat & shaft part for earthquake mini tiller all sites are impossible to use help help help
Jul 19, 2010 | Ardisam Inc Earthquake Mini Cultivator
Ardisam Inc Earthquake Mini Cultivator Logo
343 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
