Tried to use my Scott's ride-on mower for first time this year. It ran fine for about 15 minutes, then started running rough and putting out a lot of white smoke. A friend suggested water in the gas might be the cause. I drained the gas tank, installed a new fuel filter, and put in fresh gas. Again, the engine ran fine for a few minutes, then ran rough and put out white smoke. How can I solve the problem?
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
model 247.889571,drained fuel tank removed carb for cleaning. emits a lot of blue and white smoke. blue on start up. white as it is shutting down
Oil and gas white smoke coming from muffler
