The cone that comes down into the water is fine, but the part it attachesto on the top is broken, the motor sounds like a plane taking off when it is run now. How do I get a new part, because everything else still works.
You can do one of two things: order a new spin wheel from ainbow, or you can go to Lowe's or home Depot and get a product called GOOP. Get Marine Goop if the store has it. Put toe Goop on the edges of the broken parts and let it set a minute and then put the two broken pieces together. Spread a thin layer of GOOP over the crack onto both broken parts and let is set about ten minutes or so while you hold them. set the part down in a way that doesn't throw the parts off kilter and let them dry overnight. Problem should be fixed.
