There is a plastic spacer that goes between the carburetor and the block maybe that is missing if not check on Parts Tree Repair Clinic the may have a video that will help good luck.
? 4:56
www.youtube.com/watch?v=-fUJlQ1BQcs
Apr 12, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the dispenser auger drum is when ... Whirlpool, Kenmore, KitchenAid, Roper, Estate, Maytag, Crosley, ...
Most likely the orings between the cylinder and cylinder spacer and orings sealing the cylinder spacer to the body. The cylinder spacer is the white plastic piece visable when you pull off the head. Order the oring kit and replace all the orings in the lower part of the gun. Dewalt used some vinyl orings on the cylinder that failed. The trigger also has orings that will fail. Good idea to order a trigger valve and have it ready( or replace now if the gun is several years old). Good luck and post again if you have question about this gun.
bottom plastic door spacer is pt # WR01X10297 COST 7.35 . TO REPLACE OPEN DOOR AN SUPPORT / REMOVE BOTTOM HINGE PLATE AND REMOVE . REVERSE TO INSTALL . hope this helps mm parts are found and any appliance dealer or on the web at several dist . .. feed back pls ..
impeller is jammed onto shaft ,remove motor with 1 bolt ,remove impeller by putting a plastic pen in bottom of motor turn impeller counterclockwise inspect for clearance or obstruction.either replace impeller or do like I did and put a spacer,poor design on keeper circlip caused my problem.I got my spacer from a scooter wheel between the bearings & cut off enough plastic on the impeller shaft for clearance,always good to have a spare scooter wheel laying around!!!!!!
