It could be that you have some sediment build-up that has clogged the sediment screens on your supply hoses. You'll need to remove them from both the supply valve and the washer to get everything cleaned out and working properly again.
Turn off the water supply valves to both the cold and hot water hoses and remove them from the washer and the supply valve. Check inside the washer water inlets and see if there are sediment screens inside the hot and cold water inlets. If so, remove them using a small pick so you can flush them out of any debris, as you want them as clean as possible. Also check the hoses to see if they have screens in them at both ends, if so, remove them and clean them too.
Put everything back and you should be all set. IF, however, there isn't any sediment buildup in the screens and hoses, you'll have to replace the washer's water inlet valve, as it controls the flow of water into the washing machine.
As you didn't provide a model number for your washer, you'll have to go to
www.searspartsdirect.com and enter in the full, complete model number so you can check for any replacement parts you might need. The site also has a line drawing and parts lists for appliances, so it's helpful when you're undertaking a repair.
Hope you find this Very Helpful and best regards!
I checked the filter, not clogged. I reversed the hot and cold inlets and now I get hot water only, when I put the temp switch on Hot Wash there is nothing; when I put it on Warm Wash or Cold Wash the water flows regardless of which inlet hose I hook up to the hot inlet valve.
I will order a new part and reply after I try it.
Thanks
Check the inlet on the hot water hose for a clogged filter.
