Cuisinart SS-700 5-Cup Coffee Maker Logo
Anonymous Posted on May 20, 2013
Water continuously comes out when you press brew
When you press "brew" the water comes out and does not stop until you turn off the machine. It is cold water, not hot.
Chris Weiser
Level 3:
Master:
  • Master 563 Answers
  • Posted on May 20, 2013
Chris Weiser
Master
Level 3:
Master:
Answers
563
Questions
0
Helped
162557
Points
1650
Water flow meter failure. Not to familiar with this brand though.
tip
How to calibrate a Bunn CWTF commercial coffee brewer
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
1helpful
2answers
On/off button doesn't start flashing for descaling on Illy Coffee Machine X7.1
You will know the machine wants to be descaled when the red alert triangle is blinking (lower right part of control pad)
1) Machine must be OFF and cool in order to descale the machine!
2) Fill the water container to MAX with very warm faucet water.
3) Add a packet of Illy / Urnex Dezcal or similar citric acid based descaler to the water, stirring it in until dissolved.
4) Replace the water container into your Illy Francis Francis X7.1 Iperespresso machine.
5) Place a 1L (minimum) plastic catch bowl (or other suitable container) under the brew head AND frothing wand, which should be pointed toward the center of the stage under the brew head (as in video above).
6) Power the machine ON.
7) IMMEDIATELY depress and hold only the BREW (coffee cup symbol) until the machine emits THREE SHORT BEEPS, followed by ONE LONG BEEP. Release the BREW button after the long beep.
8) Press the BREW button again, as you would when brewing a cup of espresso.
9) The machine will begin to PULSE, and the STEAM BUTTON will blink. The machine will alternate between pulsing water through the brew head opening and the frothing wand. This will continue until the water container is EMPTY. Be ready to remove the water container, and IMMEDIATELY refill it with cool (Brita filtered or distilled is best) water, and replace it as quickly as possible. The machine WILL NOT STOP THE DESCALING CYCLE, so replace the water container as quickly as you can. You will probably need to empty the catch bowl at least once or twice during this procedure, and the water will be VERY HOT, so use caution!
10) The machine will continue to pulse between the brew head opening and the frothing wand.
11) The machine will stop pulsing at some point during this second tankful, and the BREW button will begin to BLINK, with an alternating BEEP between blinking. If there is very little water left in the water container, fill it up with cool water again. Empty your catch bowl if it is full and you haven't already done so! Once everything is back in place, press the blinking / beeping BREW button, which will begin to rinse the machine through.
12) The machine may repeat Step 11 more than once!
13) The machine should now come out of DESCALING CYCLE on its own, with the red POWER button illuminated, along with the blue BREW button being on and solid.
14) Run one or two BREW cycles, with cool, filtered water.
15) Run the STEAM cycle for a few moments, as you would when frothing for a beverage, to ensure no descaler remains in the frothing wand.
• Your Illy Francis Francis X7.1 Iperespresso machine is now descaled! see less
1helpful
Tassimo. Why do descaling light and water light turn on in the middle of brewing, then machine stops?
fill it with clr and run it 2 times,then run it with fresh water each time 2x to rinse it,save the clr it is still good,use a water filter on the water
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
The "descale" notification continues to come on,
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
4helpful
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
3helpful
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
