Video recording audio is no functioning. video playback too do not have audio. the video i downloaded have no audio but when imported to my pc.
SOURCE: cant playback videos i recorded with my phone on my phone
you may try wondershare streaming video recorder,you can convert these streaming videos into various regular formats like MP4, 3GP, WMV, AVI, MOV, MPG, M4V, OGG, APE, VOB, MP3, WMA, etc,
SOURCE: I want to import blackberry contacts to my iPad via Bluetooth. How can I do that?
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
The following sounds complicated but it is very easy if you carefully follow the instructions.
Unfortunately, there is no cable to connect the BlackBerry and iPhone together and a user can't transfer BlackBerry contacts to iPhone directly via USB cable. So, we should export contacts out of BlackBerry and save onto a program, then import the contacts from the program to iPhone.
Things you'll need to transfer BlackBerry contacts to iPhone.
If you are the first time using Google Sync on BlackBerry. all the contacts from your blackBerry are saved to your Gmail contacts in a group called My Contacts.
Please login your Gmail and Go to "Contacts" option on the left of Gmail account.
Then you'll see a "more" menu. Click it and you'll see a drop-down menu.
Select "Export" contacts.
There are three models to export contacts out of Google account.
1. Export Group "My contacts" to Google CSV format.
Export Google contacts as csv
2. Export Group "My contacts" to Outlook CSV format. Export Google Contacts to Outlook CSV
3. Export Group "My contacts" to vCard format. So that you can import the contacts to Apple Address book or iOS devices.Such as import to iPhone, iPod touch, iPad. Export Group "My contacts" to vCard format
Now, import vCard file to iPhone
You can save the Google account contacts to computer as vCard file and download this iPhone contacts transfer program.
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
Using
and Win7
& AUDIO DEVICES
Click VOICE
That should be it.
slider to suit.
