Garden Logo
Anonymous Posted on May 19, 2013
Throttle cable assembly
Need help assembling my throttle cable to my Briggs and Stratton 675 series 190cc push lawn mower.
Andrew White
Level 3:
  • Master 2,239 Answers
  • Posted on May 19, 2013
Andrew White
Master
Level 3:
Answers
2239
Questions
Helped
910838
Points
5950
The cable you are trying to replace is the OPC cable (engine brake cable), not a throttle cable like you are trying to fit. You need to take it back and get an OPC cable, which will have the correct end on it to fit into the bracket on the side of the engine.
1 Related Answer
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 13, 2011
SOURCE: Craftsman 675 Torque 190cc 21"
If your carburetor has sat for a few months with fuel in it, the fuel may have gone bad. Fuel turns to turpentine after a while and leaves light yellow deposits behind. These deposits will keep your carb. from working properly.You need to dip the carb. in carburetor dip for a few hours to get rid of the deposits. You can also take the carb. to your local parts store where they may do it for free.
You may also have to replace the gasket and needle valve too if it has been sitting. So basically, you need to do a carburetor rebuild.
If the float sounds like it has liquid in it, you will need to replace it too.
Good Luck!
Jim
1helpful
I see no vent holes om my 675 series briggs and stratton engine fuel cap
there are holes in it should be three or four. a rubber diaphram is covering it but they are there
Where can I get a diagram Of carb & air filter parts and assembly?
HI,
See the links below for maintenance information about this mower:
https://www.ifixit.com/Device/Briggs_and_Stratton_675_Series_Repair
https://www.youtube.com/watch?v=sYMqO5H6T4o
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
2helpful
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way...
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
My Craftsman 675 190cc starts in full throttle what could be causing this
sounds like the carburetor is a little gummy and when the engine shuts off it goes to full throttle by the govenor for easy starting but is supposed to return to the set 3600 rpm. try spraying carb clean on the carb and wiggle the govenor arm to make sure it move freely
Top Garden Experts
Jay Finke
Jay Finke
john h
