F1 shows up now and then (more often now) while using the oven. Once the temp drops we can use the oven controls again. At some temps we dont have any issue, but its the same in all instances when we get F1 signal, let the oven cool then it resets.
Im thinking the temp sensor in the oven?
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure Disconnect for one minute - if error comes back, replace control board F1 - Shorted control keypad Replace keypad F3 - Oven temperature sensor open Replace oven temperature probe F2 - Oven temperature sensor shorted Replace oven temperature probe F3 - Oven too hot Replace oven temperature probe F3 - Clean temperature too hot Replace oven probe F5 - Door latch switch fault Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop) Replace control board F2 - E0 - Shorted control keypad Replace keypad F3 - E0 - Oven temperature probe open Replace temperature probe F3 - E1 - Oven temperature probe shorted Replace temperature probe F3 - E2 - Oven temp too high Replace temperature probe F3 - E3 - Clean temp too hot Replace temp. probe F5 - E0 - Check door latch F5 - E1 - Check door latch Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error Replace ERC F1 E1 - EEPROM checksum error Replace ERC F1 E2:7 - UL A/D errors Replace ERC F1 E4:2 - Model ID error Reinsert keytail. F1 E6:0 - Latch signal mismatch error Replace ERC F2 E0:4 - Shorted key error Replace keypad assembly F2 E1:3 Keytail unplugged reinsert the keytail F3 E0:5 Top oven sensor open Test and replace top probe. F3 E1:6 Top oven shorted Test and replace temp probe F3 E2:9 Bake range over temperature Test and replace temp probe F3 E3:8 Clean range over temperature Test and replace temp probe. F3 E4:10 Bottom oven sensor open Test and replace temp probe F3 E:15 Bottom oven sensor shorted Test and replace temp probe F5 E0:14 Door switch errot Test and eventually replace door lock switch F5 E1:16 Door latch not operating Test and eventually replace door latch F8 E0:17 Refrigeration error Test the cooling module. PF Power failure - Does not indicate a fault. PF occurs when power is disconnected.
WHIRLPOOL Models SF3, 30'' and 24"
F2 - Oven temperature above specifications Check 8-pin connector from temp. probe to Electronic Oven Control F3 - Open oven temperature probe failure Check wiring, replace oven probe if necessary F4 - Shorted oven temperature sensor failure Check wiring harness, replace oven temperature probe if necessary F5 - Push button stuck or faulty Check for binding of pushbuttons and control panel glass. If OK, replace touch panel F6 - Electronic control logic error (timing) Replace Electronic Range Control (ERC) F7 - Electronic control logic error (lock motor) Replace ERC. F8 - Electronic control logic error Replace ERC.
Hello,Please use the chart to determine which stove you have. You will have
to look at the model number. The first 3 numbers will be the series on
the chart. In most cases an F1 error would require replacement of the
electronic control. This part is commonly refered to as an EOC or ERC.
However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric) F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper) F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool) F1-E0 EPROM Error - Electronic Range Control (ERC). F1-E1 EPROM Error - Electronic Range Control (ERC). F1-E2 U/L ERC Errors - Electronic Range Control (ERC). F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric- “9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error. Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE - 790 Series Electronic Oven Control (Frigidaire) F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error. Runaway Temp = Replace Electronic Oven Control (EOC).
replaced the EOC, still f1 shows up exactly as mentioned previously, when oven reaches temperature we get f1 signal
