LG LMVM1935 Convection/Microwave Oven Logo
Anonymous Posted on May 18, 2013
How do I unlock the key panel
My daughter said she just stopped the microwave by opening the door before it was done, but I think she somehow accidently locked the panel.
William Miller
Level 3:
  • LG Master 9,179 Answers
  • Posted on May 20, 2013
William Miller
LG Master
Level 3:
Answers
9179
Questions
Helped
4481414
Points
21747
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
1 Related Answer
Anonymous
  • 242 Answers
  • Posted on Jan 07, 2009
SOURCE: Microwaves
I can help solve this fiasco , opening the unit while its running to stop it is not good to do because it will wear the door switches due to the load of power the unit uses while running the switches are not made to cycle the unit.
2nd there is radiation in the unit and around the unit while running so you should not reach in inside the unit immediately when stopped , give it a few seconds. Some commercial microwaves have an un-safe level of radiation 20+ feet away from the unit.
Most likely why they always get the order wrong.
Hope this helps.
Phil
2answers
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Microwave turns on when door is open and turns off when door closes
Good Morning friend, thank you for your post!
Based off the information you have provided your microwave will start when the door is open and stop when it is closed. It sounds like a possible issue within your control panel or door latch assembly. I would suggest you reset your microwave which can be done by unplugging it for roughly ten minutes.
If that does not correct the issue I would consult a professional technician to come out and properly diagnosis your appliance. I hope this has been helpful. -Matt
My GE JE1640GB MW kept running after I was done using it. I held down the Off button to try and reset it, which locked the unit (unit reads "Lock" and diplays an L when running). I need to...
Thank you so much for the info. The WD 40 worked perfectly on the door and my microwave in not turning on every time the door is opened. This info saved me time and $. Thanks
6helpful
2answers
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
3helpful
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
3helpful
The turntable keeps rotating when the dooe is open - Panasonic T994SFR
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
It might be helpful to tell us the brand and model number, but I think I can answer this one either way.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Microwave oven door will not open. Over range oven.
hi,
it sounds like the child lock may be on...
if there is a key on the pad that says "child lock" press and hold that for 30 seconds or so until it unlocks, if there is no key that says "child lock" try doing that to the "end/stop" key or the "start" key.
1helpful
How to unlock the microwave
hi,
2helpful
2answers
Microwave auto-starts when door is closed
You probably have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
