SOURCE: Loud squeaks during wash cycle
check your underwears for missing metal parts.sometimes the ...bras missing metal parts
SOURCE: make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
SOURCE: New GE washing machine. It
Didn't like the idea of having to pay for your advice. I called the company and they told me what to do.
SOURCE: Squeeking during wash cycle
Hi jbramwilliam
I'm Harvey the Master Plumber.
Sometimes this is caused because something is now rubbing. Make sure:
The screws are secure to the counter,
The d/w is perfectly level,
The legs are all tight to the floor,
If the back legs are wheels then shim with wood blocks.
If it still squeeks then you have a warranty problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: GE Profile WPRE6100G will not spin
hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
