Computers & Internet Logo
A
Anonymous Posted on May 18, 2013
Nytouch tmobile genius button not working. get message "Sorry! The application Genius Button (process.com.nuance.android.vsuite.vsuiteapp) has stopped unexpectedly. Please try again." Then there is a force close button. When I hit the force close it just pops up again. When I ask it to call someone it does not recognize the command. Help!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 18, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
647
Points
0
T-Mobile posted a solution to this problem here (I had the same problem and this resolved it): Error "The process Genius Button has stopped unexpectedly, force stop": myTouch Q by Huawei
  • Tina Carrasco May 19, 2013
    Omg I had the same problem with the pop up.. so annoying but I fix it... ok this is happening because of a new update with google play music..first you gotta turn off auto update for google play music..
    1. Tap app from home screen.
    2. Tap play store
    3. Tap the menu key
    4. Tap setting
    5. Tap auto update app and place check in "do not auto update"
    - After that u need to go back to your old update
    1. From the home screen tap menu
    2. Tap settings
    3. Tap applications
    4. Tap manage application
    5. Tap all
    6. Tap google play music
    7. Tap uninstall update
    8. The google play music should be back to normal and the pop up should be gone.... it worked for me, hopefully for you too =)
4 Related Answers
Anonymous
  • Posted on Mar 06, 2009
SOURCE: Crazy Tablet - Genius 8x6
I have same tablet and the biggest problem is USB cable!!!
USB able is made from bad materials and the plastic/rubbery coating of inner wires of USB cable is very easy to brake, then the wires inside of the cable get connected between them selves and all the problem that you have starts.
I had those problems and all was solved by changeing the USB cable.
Changeing the USB is litle bit problematic becous it is connected to the tablet by microconnector that is wery hard to find (for me it was inpocibile). Becouse I couldn't find the matching microconnector I connected new cable to the one on the old cable welding the wires to the ones on the microconector . AND IT WORKED!!!
You may consider to by new tablet becouse this may seam complicated, but for me it was an interesting thing to do and it payed out. Just watch out to connect all the wires properly!!!!!
I hope this was helpful :)
Sorry for bad english ;)
P.S. If you have any problem while doing this write me here and all try my best to give you answers.
Steve from Serbia!!!!
Anonymous
  • Posted on Dec 25, 2008
SOURCE: Genius MousePen 8x6 Problem
Hi, i just got the Genius MousePen for Christmas and this exact thing happened yo me. i thought i tried everything! but i was wrong. ok.. first, unplug your pad, then you go to your start menu, go to PenSuitePro, and click the pen commander. it will show a little icon down in your lower right of your screen. then it will work. the only thing i am trying to find out now is how to lift up the mouse pen and leave the writting on my screen. if you know how, please post it.
Anonymous
  • 2567 Answers
  • Posted on Jun 13, 2009
SOURCE: genius graphics pad 1812 series
1. Go to: http://www.geniusnet.com/2. Click on "Service & Support"3. Click on "User's Manual"4. Click on the tab labelled "Tablet"5. Find your tablet model on the page.6. Click on the appropriate language listed opposite to your tablet's model. The download of your tablet's user manual will start.
Anonymous
  • Posted on Feb 06, 2008
SOURCE: PenSketch 9x12 hangs in Photoshop CS2 (mac)
I had the same problem on Tiger , but not anymore. The tablet does not work on 10.5.1 Leopard at all!
Instalar sin cd
Fausto, Check the attached links to driver for web cam. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.geniusnet.com/Genius/wSite/np?ctNode=118&mp=3
Genius Web Cam Webcam drivers
Genius Webcam Driver Free downloads and reviews CNET Download com
MI CAMARA ES WB 918 LA #ABM
ISTALAR AMY COMPUTADORA
Fausta,Check the attached links,drivers for Genius. Good luck
5helpful
2answers
Process com.wmt.launcher for program start-up screen has stopped unexpectedly. attempt again
the application wmtlancher (process com.wmt.lancher) has stopped unexpectedly.
How to trun on genius
How to Turn on Genius
The iTunes Genius feature suggests and recommends new music, movies, and television shows based on your device's music library and playlists. The Genius feature can automatically create new playlists for the user to enjoy and will do so based on the different genres and styles of media already present in the library. Using Genius, you can discover new music that's interesting to you.
Instructions
1Open iTunes on your computer.
2Click the "Store" menu link then click "Turn on Genius."
3Click the "Genius" entry in the iTunes sidebar to the left then click "Turn on Genius."
4Select a song in your iTunes music library and click the Genius icon located at the bottom of iTunes. The icon is represented by an atom.
f you are using iTunes for the first time, you will see Genius listed on the left side of the iTunes window above Playlists. Click Genius and then click Turn On Genius to start using Genius. You can also start Genius by choosing Turn On Genius from the Store menu in iTunes, or by selecting a song from your library and pressing the Genius button at the bottom of the iTunes window.
When starting Genius, you'll be asked to sign in with your Apple ID or create a new one and agree to the terms and conditions.* iTunes will then proceed to gather information about the contents of your library, send this information to Apple, and download Genius results. The time to complete this process will vary depending on the size of library information and the amount of traffic on the iTunes Store. At any time during this process you can use iTunes to play music or other content.
To turn off Genius, simply choose Store > Turn Off Genius in iTunes.
Hello, my lg optimus swift is not working correctly. when i turn on the phone, sometimes it displays this sorry! the application Android Phone (process com.android.phone) has stopped...
my lg optimus swift is not working correctly. when i turn on the phone, sometimes it displays this sorry! the application Android Phone (process com.android.phone) has stopped unexpectedly. And it not receiving or sending any calls with the signal only dropping.
1helpful
HI , I NEED A SOFTWARE TO MY CAMERA "GENIUS EYE 310" ,THANKS
please go to this url --- > http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-Eye-310-Driver.shtml and click download button
3helpful
How do i get rid of error message "the application Open House (process android.process.acore) has stopped unexpectedly. Please try again."
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
Instaling Genius MousePen 8x6
Installation CD is defective. Ask for its replacement.
Grand Canyon Tech
Grand Canyon Tech
