Question about Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive
Lexar memory stick
How do you use a lexar memory stick?
  • 385 Answers
This device should be plugged into any computer that has USB ports to plug into. Usually, you plug it in and you will see something pop up in the bottom right corner of the screen about installing usb drive. When it is done installing (usually takes about 1 minute), you can open My Computer and see it in there as a removable drive. Open it and save your files directly in there by copy and paste or drag and drop.
Thanks,
Lolita
Posted on Mar 18, 2009
SOURCE:
Lexar memory stick 4Gb
Maybe your stick was not formatted at all.it can be possible that the area of memory that is not visible is occupied by a virus.i once faced that prob but i used KASPERSKY INTERNET SECURITY.Its one of the best try scanning the stick that is if you havent tried it yet.Hope it works
Mar 22, 2014 | Computers & Internet
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
Lexar 8GB wont work. when i insert it, it shows up on my computer as connected but then when i click on the lexar icon to view my files on it, it doesn't open, the message: 'please insert disk into drive...
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Oct 05, 2010 | Lexar Professional High-Speed 2GB Secure...
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
Jul 11, 2010 | Lexar JumpDrive Classic Portable USB Data...
How do I empty the Lexar memory stick to create more room?
if you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Jul 10, 2010 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
When I plug in my Lexar memory stick, and try to save a file to the removable drive (J) which is the memory stick file...it says I can't because it doesn't exist. Help?
Hi, Neil.
Look in "My Computer" to see if another drive letter was created when your memory stick was plugged in. Sometimes, another drive letter is created. Try dragging and dropping the file you want to save.
In case you are not aware, in each computer, the drive letter for a memory stick could be different, depending how a computer is set up.
Also, try in another computer to see how your memory stick works (if it's OK).
Hope this helps.
Oct 25, 2009 | Lexar JumpDrive Classic Portable USB Data...
Saving emails to lexar memorty stick
Copy and past
You copy the mails and past them on the stick
Good luck to you
Dec 28, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Problems with inserting a new lexar SD card
Your pc model only supports the sony memory stick type of media.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 14, 2008 | Sony VAIO PCG-K25 Notebook
Brought a Lexar 2gb Memory stick pro duo, when I put it my camera. My camera displays memory stick error. Look for help or possible fix.
Check if your camera accept that capacity first.
If yes >>
Reset your camera to factory settings
Format the Memory stick and try again.
Oct 03, 2008 | Creative Labs Sound Blaster Audigy 2...
Memory Stick Error, PLEASE HELP!!!
Does any other Sony memory stick still work in your camcorder? If yes, means memory stick isn't match with this camcorder. Use Sony memory stick.
Jun 09, 2008 | Sony Handycam DCR-TRV20 Mini DV Digital...
Lexar 64MB FLASH MEMORY DRIVE USB 2.0 - (JDCL064231) Hard Drive Logo
192 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
CarlosIjalba
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
