I get this erroneous message-more than one ink tank of the following color is installed cyan
After reading the suggestions here, I tried cleaning the contacts of the cartridge with a Q-tip cotton swab, SLIGHTLY dampened with rubbing alcohol. This seemed to pretty much stop the problem, though it did re-occur occasionally throughout the life of that cartridge. Once I replaced that cartridge, it has never happened again. I guess this shows that you can (rarely) get a cartridge with bad contacts. If this ever happens again, I would return the cartridge to the retailer and get a new one.
P.s. PS Dave: ur a jacka$$ :(
According to Canon's website:
Details
Print Friendly Version
Issue:
ERROR LCD: More than one ink tank of the following color is installed U071
Solution:
Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank
Use the following procedure to replace empty ink tanks or when an ink tank error appears.
Ink Tank Lamp indications
Note:
When the scanning unit (printer cover) is opened more than ten minutes,
the print head moves to the right side. If this occurs, close the
scanning unit (printer cover), and open it again.
Note: Tear the orange tape carefully along the dotted line. If the orange tainaccurate error message - 05sj00141_06.jpgting problems may occur.
<4> Tape is completely removed.
<5>
Tape remains. Remove the orange protective cap located on the bottom of
the ink tank by twisting as shown in the diagram.
Caution:
Do not touch the ink tank contact <6>. Doing so may cause
printing problems. Do not squeeze the side of ink tanks as this may
cause the ink to leak out. Do not reattach the protective cap once you
have removed it.
Note: Press the inaccurate error message - 05sj00141_08_en.gifn the ink tank firmly until you hear a click.
<7> The ink tanks are installed properly.
<8> The ink tanks are not installed properly.
Note: Click for Ink Tank Lamp indications.
Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
Note: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
I am having the same problem. I found a few other forums on this issue that suggest cleaning the contacts on the cartridge. Opening the cover and reseating the cartridge only worked the first few times for me and now even cleaning the cartridge fails. Only other thing is to replace the cartridge all together I guess.
lift cover and reseat
Canon Pixma iP4200
When I go to print I get the message 'more than one ink tank of the following colour is installed. Black (5). Use only one ink tank per colour at a time.' I have to click the cancel printing button.
I turn the printer off. Turn on again - then open the lid to see the Black (5) ink is flashing - so I remove it and then put it back then close and go to print and it works OK.
WHY?
I have had the same issue for the past two weeks. It is very annoying.
I've had a Canon mp500 printer-copier-scanner for a few years and it's been flawless, until the last couple of weeks. Now I'm getting an error message saying there's more than one ink cartridge of a specific ink color installed, and it won't print. I have to "cancel" the print job. There is of course only one cartridge of each ink color installed, and none of them needs replacing. Any ideas, anyone?
I'm having the same problem. It is very irritating. I have had some success with taking the cyan tank out and putting it back in but not always.
