yeah, red means gonna die green means you have a charge orange means its charging, and when it turns off its full yeah,
red means gonna die
You can't post conmments that contain an email address.
you need to replace the battery its failing to hold charge if its under warranty nintendo will do this for you, if you know anyone else with a dsi see if they mind testing the theory out by swapping batteries for a bit, turn off dsi light begore removing the batteries,
hope this helps?? try ebay for a new battery
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Hey everyone, not sure if this will work for everyone, but its worth a shot. my problem was identical to all the others here, a flash of orange and then nothing.
i thought perhaps those little metal contacts on the battery and the ds had build up a little corrosion, interrupting the charge. so, i took some rubbing alcohol and q-tips and gently scrubbed them clean, both on the battery AND the ds side.
After this, my ds has worked flawlessly. Hope it's the same for you!
Thanks for the tip... I noticed that after I let the battery go low and then replugged the charger. The 2 led lights came on.
