I cannot log-in to config page of my p-660HW-T1 modem. I have looked for my default gateway(it's 10.0.228.1) and i could go to log-in page already. But the problem is when i enter password, there's nothing happen. I have read manual and search in the internet, so far i can know that the default password is admin (i also try 123,1234,12345,Admin,ADMIN). But it's no use (of course i have pressed reset button already). I only need to log-in so i can do config myself.
Please, i need some help
SOURCE: Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
SOURCE: I`VE GOT ZYXEL P-660HW-T1 WIRELESS MODEM I BOUGHT
You will have to reset the router to factory settings. There is a small hole in the back, depress the microswitch with a paper clip when the power is on. The default password is 1234. Some of these devices are general, while others are hardwired to work with certain providers. So if, say, this 660 is branded with embarq it is unlikely that you can set the parameters to work with other providers.
I should mention that if you care about security you should not use WEP - a cracker can break an internet connected WEP device in minutes with the right toolset. The protocol has many problems that simply can't be fixed, period. Consider using WPA2 with WPA backcompatability, as allowed by the 660.
SOURCE: I have a Zyxel P-660HW-T1 V2 and cannot conect to
hello i had the same problem after i reconfigured mine i could not gain
internet access but as it turns out i hadnt payed my bill so it wouldnt
allow me access with the same router as you
p.s my isp was digiweb
Hope this helped
this model of modem only required you to enter password.
BTW i have solve it on my own ....
How stupid of me, it require you to hold reset button for 10seconds >.<
well this model of modem only need you to enter password to log-in.
BTW, i've solve this problem by my own.... How stupid of me, it need you to hold reset button for 10 seconds >.<
