Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Check and replace damaged component/s at its main power regulator section circuit. If you wish to get more details, surf this link.
There are more than two thousand and four hundred posts. All are related
to television and other domestic electronic equipment service help.
You have a bad capacitor. A bad capacitor will show low voltage and move to a point where it may not operate this TV. This capacitor may be located near the tuner, or it may be near the flyback and always suspect those high voltage low Mf capacitors. Such as 160 volts to 200 volt at 1 Mf ,2.2Mf, and 4.7Mf. These are most certainly contributors to your problem! At its worst point the tuner may need resoldered or replaced.Hope this helps you. Thanks for asking me!
You may have a clogged drain filter. Remove the bottom front panel to access the filter. Unscrew the filter,clean and replace the filter. Also,run 2-3 wash cycles with no detergent at all. When using HE detergent,use the exact specified amount. With front load machines more is not better.
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
my jensen vm9510 ts turns on and you can listen the radio dvd's cd's but the screen do not come out even if you reset it and press the open button, so you can't seen anything is already coded to play dvd's with out eh parking brake. If any one can help me please.
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
