You need to follow the below steps to change the language. 1. In Idle mode, press <Menu> and select Settings → Phone settings → Language → Screen text. 2. Select a language. 3. Press <Save>.
To change your ringtone:
- In Idle mode, press <Menu> -> Settings -> Phone Settings -> Phone profiles
- Scroll to a profile
- Press <Options> -> Edit -> Voice call ringtone
- Select a ringtone category -> a ringtone
- Press <Options> -> Save profile
By the way, you can download your Samsung J700 Manual here: > Link <
Hope this helps.
For both of you, the answer isn't easy....unless it's already set up in the sytsem and you just have to dial the magic number :-)
Depending on how it was installed, the Pana TD system has either automatic or manual switching to DAY/NIGHT mode. If your NIGHT program is set up to send calls to voice mail, you can just put the system in nights by dialing 781 on the intercom, and I think in a TD you can do that from any phone. 780 returns it to days. IIRC the * button on a idle display phone will tell you what mode the system is in, as well as when you dial the 78x codes, it will beep once if it changes or twice if it was already in that mode.
If none of this works, or you already have Auto D/N switching set up and it doesn't or never worked, it's going to require some system programming. Your friendly Pana installer will be happy to do that for you.
Press [ / ] to adjust the volume. During a call, the exposed keys are locked. Press [Centre] to unlock the keypad. To change the sound profile: 1. In Idle mode, press [Centre] and select Settings → Phone profiles. 2. Select the profile you
I would say you would need to go in and change your settings. If you have an option to have a screen saver or not, that would probably be where you can change whatever comes up during idle mode.
