Water Heaters Logo
N Gondza Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a bosch YS2433R 'Highflow' hot water system. It has a YPRM34XB controller. The controller constantly flashes the number '99'. My home has no hot water. How do I fix this error on the controller so that I get my hot water system operational again??!!
  • Anonymous Mar 29, 2014
    there is no hot water
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 234 Answers
  • Posted on Mar 19, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
234
Questions
0
Helped
162875
Points
513
My Bosch Highflow 25 EC hot water heater loses the pendant displays on cool to cold mornings , what could be causing this annoying fault ?
Losing pendant displays on cool to cold mornings with your Bosch Highflow 25 EC hot water heater could be caused by temperature-related issues affecting the display module. Cold temperatures can affect electronic components, causing them to malfunction. It's possible that there could be a loose connection, moisture buildup, or a fault in the display module itself. I'd recommend contacting Bosch customer support or a qualified technician to diagnose and fix the issue.
Why is the Bosch high flow 21e system while showering going cool & then returns to the set temperature?
If your Bosch Highflow 21e hot water system is experiencing fluctuations in water temperature while showering, it could be caused by a few different factors. Here are some possible reasons for this issue:
  1. Flow rate too high: The hot water system may not be able to keep up with the demand if the showerhead or tap is allowing too much water to flow through. This can cause the water temperature to drop suddenly. Try reducing the flow rate by turning down the tap or using a low-flow showerhead.
  2. Water pressure fluctuations: If the water pressure in your home fluctuates, it can cause the hot water temperature to vary. This can be caused by various factors, such as other appliances using water at the same time, or changes in municipal water supply pressure. Installing a pressure regulator or a flow restrictor may help to stabilize water pressure.
  3. Blocked or dirty water filter: A clogged or dirty water filter in the hot water system can restrict water flow, causing the water temperature to fluctuate. Check the filter and clean or replace it if necessary.
  4. Malfunctioning thermostatic mixing valve: The thermostatic mixing valve (TMV) regulates the water temperature in the hot water system. If it's faulty or dirty, it can cause temperature fluctuations. A licensed plumber or technician can inspect the valve and replace it if necessary.
  5. Faulty temperature sensor or control board: If the temperature sensor or control board in the hot water system is faulty, it may not be able to maintain a consistent water temperature. A technician can diagnose the issue and repair or replace the faulty component.
If you're unsure about how to diagnose or fix the issue with your hot water system, it's best to contact a licensed plumber or technician for assistance.
1helpful
Bosch YS2039R service manual
Can someone please help me fine a link to a Bosch highflow 18e hot water system manual to set the temperature or send it to my email [email protected]
Hi my Bosch 18 e highflow instantaneous hot water service, turns water cold after a minute or so then stays cold. When you turn the water off the pressure valve keeps pulsating for about 5 seconds. The...
Open following link for Bosch troubleshooting resources, including contact phone numbers and possible manuals.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
If the conversion was made 3 years ago without a problem since, it might not be a factor.
12helpful
2answers
I have a bosch YS2433R 'Highflow' hot water system. It has a YPRM34XB controller. The controller constantly flashes the number '99'. My home has no hot water. How do I fix this error on the controller so...
Solution for a code 10 or 99 (for my own reference as much as anything!)
Hit change and the down arrow on the controller for 3 seconds.
Wait for the controller to beep and display 00 before using the down key to display 93.
Hit the On/Off button until 000 is displayed on the screen.
Press change and down simultaneously and the controller should revert to the pre set temperature. Hey presto! Hot water!!!
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
No hot water
diaohragm valve or micro switch
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
