Canon MultiPASS F80 All-In-One InkJet Printer Logo
Anonymous Posted on Mar 18, 2009
Waste ink tank removal
Two part question - repair and code. I got a message that the waste ink tank was almost full. Went on line to get code to use copier without changing. Would like to empty the waste ink tank, but I can't even figure out how to remove the panels necessary in order to access it. How do I accomplish this. Once I empty the tank, will I need to enter a code to operate the machine again?
  • phehli Mar 28, 2009
    same problem
  • augustine yabina Sep 11, 2013
    where is the actual waste inke tank located?
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Feb 13, 2010
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814473
Points
14613
Ok
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Testimonial: "Very helpful. Would still like to empty the waste ink tank for copy quality purposes. I need an exploded assembly diagram / service manual. Any thou"
  • Clive
    Clive Feb 14, 2010
    Hi there
    You can take it apart to clean but you have to be carefull doing it inside you cant miss it there be pads imside just clean all out but be careful of any wires when take apart.
    Some printers can be tricky.
    All the Best Pineworks
Canon multipass pixma mp500 waste ink absorber full
printers are cheap buy a new one or look in a dumpster where university students live and have been throwing out junk cuz they are done with school.
3helpful
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
2helpful
3answers
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
MY Pixma IP90v has an error message waste tank full. Can I fix that myself or do I have to take to a repair station?
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
You should send it to service centre
Waste ink tank nearly - message
it won't stop until the ink absorbers are replaced and the error reset in canon diagnostics. A shop repair, around $100.00
3helpful
Printer sending message
Waste ink tank/pads getting full.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need to actually get a SERVICE MANUAL, to refer to that removal procedure.
You may want to try doing a general search on the "Fixyourownprinter.com" printer repair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.
2helpful
2answers
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
3answers
Error Message
Contact Canon support ot refer to
www.fixyourownprinter,com
type your printer make model in the field.
7helpful
2answers
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
old marine
old marine
ZJ Limited
ZJ Limited
