I cannot sign in the yahoo messenger
Why let go to the passwork
Yahoo download problem
My instant solution to solve the current Yahoo, Hotmail and internet problems is too jail all the criminals and LIARS running these companies and employ HONEST people to manage them.
SOURCE: cannot sign in yahoo messenger
It may have 2 problems and 2 solutions:-
Firstly, this error occurs when your connection preferences are notproperly set. I'm not talking about your Yahoo! ID and Password here,but you may need to adjust certain features depending on what networkyou're on. Let's says for example, if a firewall protects your network,it may block yahoo messenger when it tries to connect to the server.You need to change your connection settings, click the Messenger menuin yahoo messenger and select Connection Preferences. Select FirewallWith No Proxies. Select your Internet Connection type from thepull-down menu at the bottom and enter your Home Country if theseoptions aren’t grayed out. Click OK and login again using the newsettings.If this option doesn’t work, click Connection Preferences inYahoo! Messenger again and select No Network Detection. Try to loginagain using the new settings. In some instances, you may need toprovide yahoo messenger with the IP address of your firewall or proxyserver (you can get this information from your network administrator orfrom your Internet service provider). Click Messenger and selectConnection Preferences again. Select Use Proxies. Enable either theHTTP Proxy or the SOCKS Proxy as needed and provide the proper address.Click OK and login again using the new settings.
Secondly, if you are using IM9 there are sign in problems. This is whatyahoo has to say.Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issuesthat have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix thatproblem. Even if you were experiencing a different kind of sign-inissue, I recommend installing this latest version.
Hope it can be helpful!
If you satisfied with this information, please do support me...
Thank You!
i cannot sign in to yahoo messenger. it keeps on saying "messenger encountered a connection problem. please check the network connection and then click "try again". (81003004).i already disable all firewalls but i still dont know what to do. tnx
error :
There was a problem signing into Yahoo! Messenger.
Please try again a litle bit later. (81003005)
now i acess my YM thru my email. :P
I have had both error messages described above.
cannoy sign in yahoo messenger
Messenger encountered a connection problem. ... connection and then click 81003004
