Can not remember how to hook up the throttle cable and governor linkage a diagram would work showing how all everything went back in place plz help
Wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
http://www.m-and-d.com/pdfs/briggs/135200-ms2810-0802.pdf
I have an old tiller I am trying to get running just to do it. A friend gave it to me and said good luck. The engine is a Briggs model 130202m type 0198 04 Code 7801050. I think I saw where it was built in 1978. Problem, it has compression and no fire. I removed the flywheel and points were stuck. I decided to go first class and bought a Briggs Magnatron coil. Still no fire. Any ideas. I am not sure how to hook up the stop switch wire. I thought I would get some juice by just spinning the flywhell but no go. Any Help will be appreciated. Bruce
Briggs stratton model 130202
Make sure the coil is not on backwards. The diagram that came with the coil points this out. Also make sure your air gap is set properly. There should be a card (tag) about the thickness of a playing card that is used to set the gap between the flywheel and coil arms. The stop switch wire should be set up the same way the old one was when you took off the old coil. Some engines have a kill switch on top of the engine by the spark plug. It's basically a peice of metal that you push down on the metal part of the plug to kill engine. If you have a switch like this then don't use the switch wire that came with the coil. (you don't need it)
550 series?
5hp briggs and stratton 135202 model # type# 1153 E2 code # 971210YB
i looked at this site before and it doesn't show how to actually put it together but thanks for the input
need diagram showing how governor hooks up on briggs model 130202
I need a diagram on the gov. linkage for a 130202, this one was built in 1980, as thats what the code says. Any help would be great. thanks
inadvance. [email protected]
I can get you a diagram no problem! what I will need from you though is the numbers off of your Briggs engine. (Model, Type, & Code) the numbers should be stamped into the flywheel cover. get me this and I will get you a diagram as soon as I can. thanks.
Mod 120312. I need a drawng showing the springs hooked up the linkage for the throttle (located under the gas tank
manco go cart
