Enjoy Full HD Video on O!Play-Combine HS900 MTS into one file without conversion for playing on Asus O!Play
These days many of us have a constantly growing media library, with our favorite music, movies, and photos in a variety of formats and locations. The
ASUS O!Play is designed to easily bring your media into your living room, without sacrificing quality. Enjoy video in
full HD 1080p resolution,full-fidelity audio, and photo slideshows on your
HDTV or home theater setup. With impressively wide format support, a wealth of connection options, and playback over a network or directly from USB and eSATA drives, the
O!Play is an elegant and modern media solution. Such a cool HD media player supports formats include full hd 1080p mts.
If you are interested in recording with HD camcorder, like
Panasonic HDC-HS900 which give MTS extension, you can directly
Transfer and Enjoy Panasonic MTS files to Asus O!Play via HDMI. However, before enjoy them with O!Play, you may want to do simply editing like cutting off unwanted or unimportant parts and then
merge or join the trimmed MTS files into 1 file while keeping the same format, without losing any quality. Sometimes you can also put them in a format for devices to watch anywhere in the house or on the go.
Now I will show you a fast way to
Cut off Panasonic HS900 MTS clips, and then
Combine HS900 MTS into one file without conversion for playing on Asus O!Play with Full HD 1080p resolution.
Step 1. Capture MTS from Panasonic HDC-HS900 AVCHD camcorder to Aunsoft Final Mate for Mac.
Free Download and Run Aunsoft Final Mate for Mac as the fast
MTS Cutter/Joiner without Conversion, and use USB cable to connect your Camcorder to PC. Then follow the camcorder wizard to import videos. After selecting the Import option, you will face the window like below to choose the video clips for importing to Aunsoft Final Mate for Mac. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for
Cutting and Joining Panasonic HDC-HS900 MTS clips.
Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split/join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created.
Step 3.
Split or cut off unwanted parts from HS900 MTS movie for Asus O!Play.
From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete.
To change video sequences, just click on the video clip on timeline, drag and drop to the left or right for the position as you like. One movie will be exported as one file with Aunsoft Final Mate for Mac.
Step 4.
Merge/Join/Combine HS900 MTS without Conversion for Asus O!Play.
Click the Export button and choose lossless output, the HS900 MTS cutter/merger for Asus O!Play will start joining large .mts files into one mts file without conversion at the fast speed. The non-conversion process will prevent loss of quality when
joining MTS files for Asus O!Play with 1080p.
After a few seconds, then connect the lossless output mts format with Asus O!Play via USB. By
Connecting the O!Play HD Media Player via HDMI with HDTV , you can
Enjoy full 1080p high-definition video and digital audio output for lossless audio transfer to your receiver or TV.
Tips: If you think that MTS file is so large that can't play smoothly on O!Play, you can also use this program to convert MTS file to MP4, AVI, MOV, WMV, etc with smaller size for Asus O!Play.
