2000 Saturn SL Logo
Posted on Mar 18, 2009
My 2000 Saturn failed inspection, EGR valve.
Can a lay man do it and how will I know if it needs to be replaced?
  • mickey2tonya Apr 06, 2009
    I just had the same problem. Napa told me it cost about $80, and would take about 1/2 to fix.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3561
Points
8
I have the same car, but haven't had this problem (yet), I've had others (I believe it to be the infamous intake gasket fold), but this was on the list of things to check.
Yes, you can do this yourself. The EGR is on the driver side, mounted on the intake underneath the air intake line. You might just need to clean it up a little though with some carburetor cleaner, a toothbrush, and by using a torxx wrench to gently move the pintle up and down while turning it left to right. If it gets stuck when you move it (doesn't pop back down), then you definetly have been having trouble with it...just tap it on the side with a wrench and it'll pop out. Repeat until it moves easily.
To remove the EGR:
1. remove the air intake line by loosening the hose clamps on intake manifold and the air filter box. Also remove the other hose running from the valve cover to the air intake.
2. disconnect the electrical cable from the top by pulling the tab out and pulling the cable up
3. Use a 10 mm socket and and extension bar (at least 4") to loosen the two bolts holding the valve on.
It takes about 10 minutes, 20 max to do, and is far cheaper then spending $180 for a new valve!
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jun 07, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
Helped
11814
Points
62
We had the same problem. we bought carberator cleaner and took out the egr cleaned it really well. and it passed the retest..
What is this code p405 in a 2000 camry
P0405,P0406andP1410 is EGR malfunction. inspect all the vacuum hoses and el connectors,remove the EGR valve and inspect for clogging in the intake or pipe, let helper start the engine and see if the vacuum on the how is strong. If no vacuum remove the intake and clean.If vacuum is good replace the EGR valve
Good luck
3answers
3answers
2helpful
2answers
Took it to mechanic after it wont stay running he said it needs a crank shaft position sensor and egr valve. Where is the sensor and how do you replace it and how do you replace the egr valve.The mechanic...
what are the codes that made him think these two parts need replacing. The egr could cause a rough idle or stall, But it would need to be stuck open a little which may not set an egr code.
The crank sensor wouldnt cause a rough idle but the car could stall at times intermittantly.
What are you exact symptoms
3answers
How do I remove and clean an EGR valve for a 2000 Saturn SL? I'm told that I need to replace it's ignition control module and two associated coils as well. Is this easy to do? I'm not sure what the coils...
buy a can of throttle body/carby cleaner take the air filter hose off the throttle body start the car and just keep spraying it in there and keep reving the engine as it will stall if you dont, that stuff will clean the inside of your engine real good plus its quicker and cheaper
3answers
2000 sl1 saturn ODB Codes
using an ohmmeter, you may be able to find the proper specs by googling "proper resistance for egr on 2000 saturn sl1"
6helpful
2answers
2000 Saturn SL2 - replaced ignition then BCM failed. Related?
the problem is not the bcm. the passlock security sensor is in the cylinder and housing, if the cyl and or housing was replaced the system must be relearned. if you replace the bcm you still need to relearn the system or it still will not start.
Transaxle control module and failed egr valve
the egr valve is mounted on the passenger side of the front head and the transmission controller is behind the drivers side front wheel fascia mounted to the frame....you will need to remove the wheel well shield to access it
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
