I want to unscribe "THE DAILY MANAGER" from my printer as I cannot read the french version.This looks like a news letter.Please remove as I have Parkinsons Disease and have had extensive heart surgery.I DO NOT know anything about computers as you can probably tell? I am not supposed to get mad,as this raises my blood pressure.Please can you please help me?
SOURCE: Do not know how to use scanner
If you have install HP s/w photosmart essential, you can scan material into coputer by selecting the get image function then select from scanner. A window will pop up. In which you can change the scanner parameter setup or accept the pre-scan quality and do the scan right away. Another method is in printer and fax folder, you can find the icon for scanner is located here too. Just click on the icon for scanner then you can get the scan result too. Hope this can help you.
SOURCE: the plastic part that the
If you just recently received the printer then it is probably still under the manufacturers warranty which means you can return it. The problem you are describing sounds like the printer was damaged in shipping and therefore, in most cases, the manufacturer should replace it for you.
SOURCE: I used disk manager to create partitions. but sata
You can use Partition Magic Pro, RANISH Partition Manager, GDISK etc.
OR else
You can download the ultimate bootcd
Click Here to Download
Have a Nice Day
Thanks & Regards
Nandu
SOURCE: I am willing to format my wd passport 250 since it
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
