Symphonic ST419E TV Logo
A
Anonymous Posted on May 15, 2013
Ge xs stereo 27gt273 - Symphonic ST419E TV
How do i reset the factory volume level on a ge remote monitor xs stereo without the remote?
[PDF]CARESCAPEâ„¢ V100 Vital Signs Monitor - GE Healthcare
www3.gehealthcare.com/...monitoring/monitors/gehc-serv...
GE HealthcareNov 21, 2011 - NOTE: The information in this manual applies to CARESCAPE V100 Vital Signs Monitor ...... PULSE VOLUME indicator: flashes to indicate you are making a change to ...... monitor is set to or reverts to factory default settings.
Ge remote xs stereo TV Model# 19GT352
It sounds that the main system control memory IC to your TV is faulty. Replace it, and re-program it with initial data values. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Ge xs stereo tv
If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1helpful
Need original remote control & owner's manual for GE XS Stereo Commercial Skip TV, Model #27GT616
To get its original remote control and user manual, you have to contact the nearest authorized service center for GE
Cannot get dish remote to work with GE 27GT271 xs stereo tv?
The remote mentioned only has about 50 codes built into it---and note: RCA and GE are the same= try all possible codes for each.
1helpful
How do I put the GE remote xs stereo monitor into input mode without the remote?
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
NEED SOUND
TRY CONNECTING THE WIRES THE RIGHT WAY
No pwer to the set
contact the power company and if you have insurance, contact them also. I am sure that the power company will help you out.
2helpful
My ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
