I think I have a color management problem or profile problem for my printer. I have an Acer T190 running on Vista Ultimate 32 bit. An Acer AL1917W monitor. A Lexar X4270 all-in-one printer. It won't print out the colors on the monitor. Probably a wrong color profile for the Lexar? If so, where would I get it?
SOURCE: Lexmark X75 All In One printing problme
Have you run print head alignment? or To clean the cartridge carrier contacts on the printer, do the following: 1. Power off the printer and remove it from the mains supply. 2. Open the printer lid so that you have access to the cartridges. 3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible. 4. Remove the cartridges. 5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom. 6. Repeat Step 5 on the second carrier slot (where applicable). 7. Reinsert the cartridges and close the lid. 8. Reconnect the printer to the mains supply and turn on the printer again. Let me know what happens. Good Luck, Tim
SOURCE: Color management and gloss paper settings
which printer do you have? Is photoprinting software supplied with it?
SOURCE: printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
SOURCE: Lexmark 1185 printer not printing in colors
Try to follow the steps at the link below:
http://support.lexmark.com/perl/support/support.cgi
SOURCE: can't find a driver for lexmark Color z35 for
Hi
I have had a look for you all over the internet.
At the moment I not think there are any for vista or win 7 they not make any sorry.
All The Best: Pineworks
