Call service --- possible bad thermistor (fuser)
could over heat
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
step by step procedure of how to change the toner
