Question about M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
How i attached 5.1 surrounded speaker to delta 1010lt,because i attached thal card with bheringer 2442 fx mixer
4 Suggested Answers
SOURCE:
SOURCE: i can't get audio to play out of my m-audio delta
i cannot uninstall or upgrading my audio drivers to my note book compaq prasario c700
Posted on Feb 26, 2009
  • 52 Answers
SOURCE: Unable to install the M-Audio Delta 1010lt sound card in Vista
Hi, Your driver CD does not have the drivers for Windows Vista on it. You need to download the driver from the internet. Below is a link for Vista (as long as you're running the 32-bit version). You can click on it or cut and paste it into your browser address bar. Click on the fastest response speed underlined link on that page to download (and remember where you download it to on your computer.) Click on the file and it should install the driver for you. Hope this helps! Hal
http://www.driversdown.com/ViewDownloadUrl.asp?ID=98906&brNum=3&show=0
Posted on Jun 06, 2009
  • 518 Answers
SOURCE: How can I connect headphone line from delta 1010LT
on output of sound cardsare coloured sockets,headphone/speaker socket is green
Posted on Jul 05, 2010
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3, M-audio Delta 1010LT With Cubase 5 . There is a main problem when it's normal with an apm it's no problem no sound problem but when the direct out is working with the sound card the...
You MAY be overdriving the sound card. Near flat should work for vocal, but setting the levels throughout the mixer is important as well as the sound card. You can use the LOW CUT to reduce hum if you have noisy system. Describing balancing the levels is more than I can do here. There are many good videos about mixer setup on YouTube.com. You cannot "fix" problems created by improper levels and noise injected into the system using the EQ.
What is important is to see that all gain controls and faders are around mid range to 70% when operating normally. You should be using BALANCED lines everywhere possible either XLR or TRS cables. ALL interconnected equipment should be powered from the same receptacle or power source INCLUDING all amps and powered speakers. Often users use unbalanced lines from mixers to sound boards and pick up noise or they have the levels set wrong between the mixer and sound board resulting in clipping and distortion or poor signal-to-noise ratio.
Jan 18, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Jun 06, 2009 | M-Audio Delta 1010LT Sound Sound Card
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Oct 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
No sound
Try installing this driver : http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=1&PID=2b0aae232aeed5529a4916b0c8c33c4b&OS=15 May or may not be compatible cause this driver is for windows xp. I don't see a vista driver yet.
Aug 16, 2007 | M-Audio Delta 1010LT Sound Sound Card
How do you set up surround sound for DVD playback in windows xp?
Do you have 5.1 speakers? Becouse you need to plug in all the 5.1 speakers to the differnt ports on your soundcard. If you only have 2 speakers you wont be able to get the 5.1 surrond sound your after and it will default to 2 speakers. If you do have 5.1 speakers then you will need to check the option in the control panel in the M-Audio window. It has an option for 5.1 surround. If your software cannot play 5.1 surround them get some other software that can.
Sep 20, 2006 | M-Audio Delta 1010LT Sound Sound Card
M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
John Bolton
Thomas F. Schneider
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
