Question about Life Fitness 9500RHRT Recumbent Bike
9500hr I am trying to do the fitness test, following the manual. when I hit start, it will not let me choose the VO2 fitness test. it immediately wants me to put in a level, instead of letting me use the up or down arrows to choose a program. There is no VO2 button to hit for that program. how do I get it to do the fitness test?
2 Suggested Answers
SOURCE:
maxtreadmill
  • 832 Answers
SOURCE: Our life fitness 9500hr recumbent bike stopped working
If this unit has not been used for that period of time then the 6v batt has died ans needs replacing call National Gym Parts @ 1-800-496-7278 to order part# LC001.5
HERE IS THE PROCEDURE TO REPLACE THE BATT:
Tilt the bike on its side, remove mounting screws securing the battery to the bracket. Remove the battery just enough to access and disconnect the black (neg) wire from the (-) terminal and the red (pos) wire form the (+) terminal. Replace battery and reverse procedure when installing battery
Posted on Apr 17, 2010
Looking for owners manual online
Here is a link to the Life Fitness support page. You should be able to locate your manual there:
http://www.manualslib.com/brand/life-fitness/exercise-bike.html
Jul 17, 2015 | Life Fitness 9500HR Recumbent Bike...
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
Sep 23, 2013 | Life Fitness Exercise & Fitness
Notify maintenance
http://fitness.manualsonline.com/manuals/mfg/life_fitness/9700hr.html?idRes=11637493
GO TO DOWNLOAD THE MANUAL FOR YOUR TREADMILL 9500HR FREE, AND EXECUTE STEP 14-15-16 and Ready.
sincerely.
Oct 17, 2011 | Life Fitness 9500HR Next Generation...
Sir, i have a life fitness 9500hr. I hit start screen reads incline inoperable. Everything else works but won't incline. Thanks
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message cardiotech_me@hotmail.com
Aug 15, 2010 | Life Fitness 9500HR Next Generation...
Unit will not start. it does work in maintenance mode. All fuctions work in the maintenance mold. When using the quick start or other setting to start workout, the unit does not start. " Please Wait " is...
Get back into System test hit enter it will automatically to a check once completed. Then go to Lift motor module Go to manual incline and go to maximum incline then to 0 incline then get out of system test unplug unit for about 30 seconds. Then plug unit in if this does not work the limit or home switch may be the culprit
Jun 29, 2010 | Life Fitness 9500HR Next Generation...
Treadmill stop then display an error speed
If the is a Next Gen unit need to enter Diagnostic menu by pressing and holding pause then press clear twice. Continue to hold pause until until read service menu. press any arrow up and select system test ,then press enter the display will begin to automatically scroll thru available options. press enter to access Main Motor Module the next window will be Speed Automatic.
Upon entering this test mode you will able to check the drive motor and motor control board. By using the the speed arrows you will be able see the actual speed if functioning if not it could possibly be the speed sensor or wire harness ( SIMPLE CONTINUITY CHECK WILL RULE IN OR OUT THE HARNESS ) and point the problem. Now if their is no belt movement then hit clear and proceed over to SPEED CONTROL ERRORS hit enter this test allows seeing the motor controller conditions that are being displayed on the motor controller display if any of these come up then the controller need s to repair or replaced:
Max Temperature, Maximum voltage, Fault Line 1 error, Static current trip and dynamic current trip ( this also can a running belt tension this can result in a cannot obtain speed error message ) hit clear to get out of diagnostic once you eliminated the problem. Good Luck!!!
May 21, 2010 | Life Fitness 9500HR Next Generation...
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
Communication timeout message on a display
You need to press and hold Pause,press clear twice. Continue to hold pause until the display reads SERVICE MENU. Press any up arrow and select SYSTEM TEST. then press enter in the desired mode,then the display will scroll automatically though available options. You want the first option which is SYSTEM COMM TEST hit enter upon do so it will perform test to communicate with all module within the treadmill. If a module does not respond to the upper console the a error message will display.
Mar 15, 2010 | Life Fitness 9500HR Next Generation...
Hi have life fitness 9500hr.when i opne MOTER
Every time I have gotten this message, I have had to replace the motor controller.
Feb 27, 2010 | Life Fitness 9500HR Next Generation...
Manual for lifefitness 9500hr treadmill old modle
Just call Life Fitness and they will send you one via e-mail attachment.
(800) 351-3737 between 8 a.m. and 5 p.m., CT Monday through Friday.
stephen
Aug 01, 2009 | Life Fitness 9500HR Next Generation...
Life Fitness 9500RHRT Recumbent Bike Logo
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
