Have installed a 16 hp kohler command engine in my ridinging lawn mower, regulator wiring is not the same. only two wires to connect.
SOURCE: Car Voltage Regulator Connection
Hi
The only thing that I need is the diagram on how to connect a voltage regulator (12 V), car unit
on my wind generator motor which my produce more than 12 V, according to the wind speed.
Sincerely
Nestor
SOURCE: Command start wiring diagram for a dodge caravan
Go to your local automotive store and get a Haynes or Chilton repair manual. Be careful installing it, it can cause major probs with the other wiring in your van.
SOURCE: 1972 Ford F100 Alternator/Voltage Regulator wiring
Here is what you need.
Please rate this a fixya
SOURCE: alternator not charging
Joe, there is no longer a regulator on this car as we would know it to be. The ecm is now also resposible for telling the alt when to turn on and off. This was done in order for the alt to be turned on and off in conjunction with the other loads and engine speed in order to be more efficiant in the long run. So from what I read here, you either have a bad wire somewhere or your ecm is toast. Replacing lights-unless for some reason the wires were cut(doubtfull) would have no effect on the alt.
