Dell XPS M1330 Notebook Logo
Anonymous Posted on May 14, 2013
Burn dvd Sense: 03 ASC: 73 ASCQ: 03 (Command 2A) ------------------------------------------------------- Px.dll: 4.28.6.0 PxAFS.DLL: 4.28.6.0 pxdrv.dll: 1.2.67.0 PxMas.dll: 4.28.6.0 PxSFS.DLL: 4.28.6.0 PxWave.dll: 4.28.6.0 pxwma.dll: 1.0.0.3
Anonymous
Level 2:
  • Expert 123 Answers
  • Posted on May 27, 2013
Anonymous
Expert
Level 2:
Answers
123
Questions
0
Helped
14387
Points
444
Put the dvd in... select files you wish to burn to dvd... then burn them.
Roxio copy dvd error sense: 03 ACI: 11 ASCQ: 05 (Command 28)
I've been using AppGeeker for several years and have been very happy with it. http://www.appgeeker.com
Dvdr cant burn audio
Update the driver of your dvdr so that you can make sure that the operating system is communicating with the dvd. You can use RadarSync to automatically update the driver.
David
1helpful
2answers
Error burning iso file on Roxio Creator Basic ver 9.0.117
I found that burning images with roxio can be a bummer, plus it is slow. Here is a free program that works great:
http://www.imgburn.com/index.php?act=download
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Will start burning CD then says there's an error
there are a lot of similar issues out on the net about this, dells computers I would switch to nero or any other burner software and see if it clears up, you might want to contact dell about it as well as I can see by the net forums its wide spread, could be a limited use lic issue.
2answers
WHEN TRYING TO BURN A COPY OF A DVD (ORIGINALLY RECORDED FROM MY DVD RECORDER ATTACHED TO MY TV), I GET THIS ERROR MESSAGE AFTER IT HAS BEEN COPYING IT FOR SEVERAL MINUTES. DIFFERENT BRANDS: VERBATIM,...
Gracie5, What I would do is find another application program to run on your DVD drive. There are alot of freeware products on the net. Your may be out dated for the current disks you are trying to make.I don't think all those disk companies can be making that many bad disk. Remember to always update!
2answers
Roxio creator basic 9 won't copy my game
if its erroring I would suggest you are trying to copy a copy protected disc. there are various protections, check the link below for full details.
http://www.cdmediaworld.com/hardware/cdrom/cd_protections.shtml
due to the fact that the item you are trying to copy sounds like it will hold a copyright I am unable to assist futher, although a good search of that site I just gave you and also maybe gamecopyworld.com may help you futher.
3helpful
3answers
NEC ND-6500A Cant burn DVD-R
I figured out what was causing the problem with my NEC 6500A on my Dell laptop: The Sony Picture Motion Browser software that I was using to burn DVD's is only compatible up to Service Pack 2 of Windows XP. The day after I installed Service Pack 3, the software stopped burning DVD's. So I uninstalled Service Pack 3, rebooted, unistalled the Sony PMB software, rebooted and re-installed the Sony PMB software and I can now burn DVD's again. So check whether the software you're burning your DVD's with is compatible with whatever version of your operating system you're operating with. Hope this helps someone else!
Hp 300 n
I know your problem however it is easily fixed, the burner has worn out, the laser basically is not putting out enough light for it to work properly, the best and easiest fix, goto tigerdirect.com and replace the burner, they now start as low as 24.00 and go up to around 65.00 so it's not an expensive fix.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
