Question about Microsoft Windows XP Media Center Edition 2005 for PC
M93 00115 cant log on to windows kb and mouse don't work to log on
I have an acer wireless mouse model mg-0766 and i cant get it to connect to my hp pavilion laptop. the batteries are fine. the dongle light doesnt come on but when i plug it in it does download the dr
Hi friend , make sure you have install the proper driver of it, if you don't have the driver or you don't know what is the exact driver, then my suggestion is you can install windows 7 operating system then i am sure it will work, or you can check it out by connecting a different computer where windows 7 is installed. make sure the usb port is working fine also.
Sep 25, 2012 | HP Computers & Internet
When logging off my laptop, and before going into shutdown, I closed the lid on my laptop. The window is now stuck showing the prepare to shutdown screen. The mouse pad still works but nothing I push will...
Try holding down the power button until the computer force shuts down. If that doesn't work, you may need to pull the battery. Don't worry about damaging files, everything should be fine. When Windows boots up again, you just need to select "Start Windows normally".
Aug 14, 2011 | IBM ThinkPad T60 Notebook
My friend logged into her own fb of my computer now i cant get my fb back up with my email and password
Try clearing your cache. This process differs between different web browsers. The following link will show you how to clear your cache in most common browsers.
http://kb.iu.edu/data/ahic.html
Hope this helps, Nathan Taylor
(Don't forget to rate)
Jul 20, 2011 | Facebook Social Network
Cant open my e-mail
You may try to logging out then clear your cache or refresh/restart browser then logging in again. In my experience, I even switched browsers but if the problem persists, don't log out but open this link.
http://wap.oa.yahoo.com/
As you can see, it's a yahoo mobile interface but it surely works like magic although there's no way you can log out from it, simply close the browser window whenever you're done reading your email while you still can't access your mails using the normal site.
Also, pictures are not viewable using the link, only pure texts from the email will appear.
Thanking you
davevipul197
Jun 01, 2011 | Yahoo Mail
Just a beep all the time as button press to switch on G27MC K52H
if it work but you hear a beep try another kayboard or take the mouse and KB off and swich on the pc if no beep that mean KB or mouse is bad change ,
if the pc not work that mean aproblem with vga card or ram
if you see that is helpful plz don't forget to vote me
best regards
Apr 21, 2011 | Foxconn 760GXK8MC-RS Motherboard
Dell xps 400 keyboard and mouse not working, but the keyboard does work in when in service mode
If it works in service mode, then it is not a hardware problem. Boot Windows in "Safe Mode" using the F5 Key as it is Booting to Windows. That should make it re-discover the KB and Mouse. Make sure the KB and Mouse are pluged into the right ports. Mouse Green and KB Purple
Dec 30, 2009 | Dell Computers & Internet
A4tech KB(S)-1527R (KB-1527R) Keyboard and Mouse
Normally there won't be an issue. Keyboards and mouse are normally capatible with all versions of windows. This set will probably come with a cd if drivers are needed to be installed for the receiver. Hope this helps.
Cheers
Sep 30, 2009 | Computers & Internet
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Microsoft Windows XP Media Center Edition 2005 for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
