If you are having trouble deciding what internet to get dsl or cable i i advice you to get cable internet its much faster than dsl and it doesnt use your phoneline, cable is one of the fastest internet out there,
You'll need a broadband connection to the Internet to do Netflix. I'm assuming you currently have a bundle; Internet with your cable TV. So you can get rid of cable tv and just have Internet through the cable company or if it's available DSL via the telephone company. You could also get Internet via Satelite, but it cost more.
hi, make sure you have your router connected to your cable modem. make sure the internet lights are blinking on both.
no internet light on modem: this indicates that the internet service provider has an internet outage. call them and see if internet is down in your area. if it is up, they will probably have to replace the modem.
internet light on modem bot not on router: this indicates that you have the cable plugged in the wrong port, or you are using a bad cable. make sure the internet cable coming from the modem is plugged into the routers "Internet" port, not the ones labeled 1,2,3,4. if that was not the problem, check with another cable.
software issues: if you have an internet light on both devices, yet the problem persists, go on your computer: 1) click the start button 2) click control panel 3) click network and internet 4) click network and sharing center 5) click change addapter settings (located on the left hand navigation bar) 6) right click on your local area network. 7) go to properties 8) click on internet protocol 4 (tcp/IPv4) 9) click properties 10) make sure you have is set to automatically obtain an ip address.
I have used Cat5e plenum Cable for my internet connection and I faced same problem. If you are just concerned with internet access and not access between devices on your LAN, then you just need to connect the first router LAN to the WAN port of the second router with the mentioned Ethernet cable. It is also in your best interest to make sure the IP ranges are different between the two DHCP servers you now have. That is, make sure they are not on the same subnet or serving up conflicting IP's.
Hello, I see your wanting play online, Your xbox needs either a wireless lan adapter if wireless internet available, if not then yes you will need a internet cable, just be careful on which cable you buy, cause not all internet cables work with the X-box systems. Hope this helps and we look forward to hearing back from you.
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
