Question about Konica Minolta bizhub C250 All-In-One Laser Printer
How do I stop daily reports from printing? How do I change the default tray for fax reports?
  • Konica Minolta Expert
  • 158 Answers
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Posted on Dec 13, 2009
  • Jo Qu May 22, 2012
    I have the same problem with my 1690MF. Activity report already changed to OFF but still printing evrytime i turn on thr printer.
SOURCE:
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
Explicit input tray for bizhub 250/350 fax.
to set the priority tray for fax reception you have to change software sw in administrator mode:
1 touch the utility/counter button
2 press administrator mode button on the touchscreen
3 enter the passwrod 12345678
4 press the admin. 2 button
5 touch software sw
6 touch mode selection then use the keypad to type 037
7 touch the bit selection button use the arrow keys to select the bit you want to change setting the bit to a 1 enables the tray and 0 disables the trayrefer to the chart below to pick a tray to print faxes from you cannot set all the bits to 0 at least one of them have to set to 1.
bit 7=1 for the 1rst tray
bit 6=1 for the 2nd tray
bit 5=1 for the 3rd tray
bit 4=1 for the 4th tray
bit 2=0 for the bypass
so lets just say you want to put yellow paper in tray 1 to have all the faxes print on yellow paper. you would set bit 7 to a 1 and set bits 6,5,4,2,all to 0
Mar 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Daily report/printout
At the end of the each day,press funcktion and then report,select activity report and press "ok"
This is the only way the activaty report can be printed at a spesific time.If you switch the report on in the report settings it will only print when the memory is near full.The other way is to switch TX report to on in report settings,but the you will get a report after every fax that you sent.
Mar 02, 2009 | Canon L220 Plain Paper Laser Fax
Confirmation
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
613 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
