Question about Dishwashers
LG dishwasher LDS 5811 WW smells really bad has a slime film everywhere it was coated all over the upper arm and lower spray arm- dishes are not getting clean- and it smells so bad- any ideas?
Our LG dishwasher smells so rotten- the dishes are not getting clean- and there is a slimey coating- all inside dishwasher - it covered the upper and lower spray arms- and inside the walls - I have scrubbed - tried a cleaner- tried different soap- and added oxyclean and jet dry- any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
It sounds like the problem is your water. go to www.dishwasherfilter.com and check out the dishwasher filtration system. it will solve your problem and works amazing. it is guaranteed or your money back.
Posted on Jun 26, 2013
SOURCE:
The dishes are not clean when we run the wash cycle. It looks like the water flow from the top sprayer is NOT working. The door, when we open it, has undesolved soap stuck in globs on the top of the door....
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking...
Even if you need a heating element and spray arms, they will be much cheaper then a new one...espec. if you install it all yourself, which is not that hard to do...
Here is a tip that will help you with the online buying...
Dishwasher Spray Arms notSpinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 16, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
My LG doesn't seem to be cleaning very well or drying. The dishes are very wet when it cycles off. And the bottom of the washer is pretty gunkey. I have used the washer detergents for removing build ups...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 15, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
I have a LG 24 inch dishwasher that is not cleaning the dishes well. After the it finished the dishes are still cold and wet. Is there a heating element that can be replaced?
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Dec 29, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
It leaks from under the front door, escpecially when it gets to the rinse cycle. LG LDS5811WW
The Vent Kit behind the lower door panel, upper left corner has a rubber, solonoid stopper. Pressure from the spray arms overcome the rubber as the stopper hardens over time, allowing water to enter into the vent blower assembly. I found my replacement on Sears-Parts for $40 w/ shipping and just ordered it today. Be sure to turn off the breaker to the washer before removing the lower front door panel - 120vac in there, don't want no electricutions.
Oct 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
I have a LG dishwasher model # LDS5811WW is there a filter of some sort at the water intake? My water has be known to have sand in it . The dishes are not all washing some are some aren't.
No filter in these units. It is possible that sand has gotten into the sump assembly and is not allowing the vario motor to properly switch between the upper and lower spray nozzles.
Dec 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS 5811 Dishwasher has white film everywhere.
You may have a water issue.  Be sure that the water line is connected to the hot water pipes, not cold water.  If your dishwasher is connected to the cold water, the soap residue will occur because it cannot dissolve in cold water properly.
Is your water very hard??  If so, you may need to get a water softener to remove the hard scales.
Jul 07, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwashers Logo
320 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
